invalid file name
Will Williamson
invalid file name
Post by Will Williamson »
When I try to write cnc I get Invalid file name pop up ? I,m lost
Will
http://www.willmade.com
Jody Wilmes
Company Name: Thermwood
Post by Jody Wilmes »
What name are you trying to use?
Will Williamson
file name
the file name comes up C:\\document and settings \\ all users\\documents \\v5 test jobCab 1.esj I'm just starting on e cab training guide book so I will have a lot of questions in the next few weeks is this the best place to find answers?
Will
Will Williamson
Batch Cabinets
I'm starting with batch Cabinets what is the ideal location to save them?
Will
Jody Wilmes
That's the job file it loaded. What is the name you gave in the bottom field?....Be sure to hit BROWSE, then type in the name of the file you wish to create. I attached a screenshot of what it should look like prior to hitting \"OK\".
Jody Wilmes
Re: file name
Will Williamson wrote:the file name comes up C:\\document and settings \\ all users\\documents \\v5 test jobCab 1.esj I'm just starting on e cab training guide book so I will have a lot of questions in the next few weeks is this the best place to find answers?
This place is your best bet for questions. Keep in mind that you can also call in for support. Have you considered coming in for training? It would definately get you up and going quickly.
Dennis Englert
Invalid Filename
Post by Dennis Englert »
Not knowing what edition of the workbook you are referring to, I can't tell you what page to reference, but that page is title \"CNC Output\" and is about 20 pages from the end of the book.
eCabinet Systems usings Microsoft file naming conventions, so you can not use special symbols, such as \", ', or /. Those are probably the most common naming errors.
Select the button at the bottom of the CNC Output screen that is labeled \"Browse\". You need to select and the address of where you want the file to go and the file name. If you are sending this to a Thermwood CNC and are connected via a network then your file can go straight to a folder at the machine and would be ready for the operator to load.
As Jody indicated you can address these questions directly by calling our support personnel.
Dennis Englert
Will Williamson
Thanks Judy Thanks Dennis
Dennis I do plan on attending training in grand Rapids I just needed a little bump to get me past this one spot I have been reading this book day and night
Will
