Two types of nesting
Gene Davis
Post by Gene Davis »
Are cabinets independent of nesting type?
By nesting type, I make the differentiation between that done for CNC, and that done for straightline sawing. In other words, TRUE SHAPE versus CUT LINE.
In other words, can I take a batch job or a \"room\" job, and produce nests both ways, without messing myself all up?
Brian Shannon
Post by Brian Shannon »
Yes you can.
Michael Yeargain
Post by Michael Yeargain »
In the e_cabinets system from the nesting area choose the radio buttons at the top left of the screen and click nest. Either radio button will produce different results.
I have found trueshape does not always give the best results. Play around with this area. It doesn't change anything in the job file.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Damon Nabors
Post by Damon Nabors »
Gene, I have been using the cut line for the last couple months on my panel saw, and found the nesting to be very acurate.
Gene Davis
OK, tried it and everything looks good.
Question for you saw shop guys: Does \"COLLAR SIZE\" relate directly to kerf width, when nesting using true shape.
If so, and you are using a rip blade with 0.133\" kerf, do you then set you collar size to the 133?
Gene,
You wouldn't want to use \"True Shape\" nesting for a shop not using CNC. This type of nest would not have \"through\" cuts to make it practical for a saw shop. The yield is better using \"True Shape\" because of the capabilities of the CNC Router.
I set the collar at 0\". The kerf is set in the Standard Dimensions area of Settings and Preferences.
Standard Dimensions.jpg (61.42 KiB) Viewed 13324 times
Here is a little more from the area help docs:
The Collar is a band around the entire edge of the sheet into which parts will not be nested. The Collar can be used to allow for slightly off sized sheets or a small amount of edge damage.
Michael Yeargain
I was just fixing to add that when I had another message popup from this post. Good thing I checked it otherwise we would have had a collision at the molecular level.
No telling how devistating that could have been.
32Gigs DDR4
Corsair RM650
Gene,
As Dan stated, when I nest using Cut Line for a saw shop I set the collar at 0. eCabinets automatically takes a saw kerf off each edge and each end of sheet goods to allow for cleaning of the edge. In other words the largest piece you can nest from a sheet that is 48\" x 96\" with a saw kerf set to 1/8\" would be 47 3/4\" X 95 3/4\".
If you have a collar value set, then the sheet size is further reduced by the collar.
Thanks Kerry...I was busy exploding the Enterprise and didn't put quite enough detail in my post.
Michael Yeargain
Despite Dans preoccupied oversight, you did a fantastic job of clarifying this Kerry.
:lol:
32Gigs DDR4
Corsair RM650
Glenn Van Reason
Company Name: TBA
Country: AUSTRALIA
Post by Glenn Van Reason »
While we are on the nesting of ecabinets, it would be good if the nesting algorythm could rotate parts independently when nesting. I have found that with some jobs by rotating a few items on a sheet 90 degrees I can squeeze a job out of one less sheet.( I get this by running the panels required through a different sheet nesting package) I know you can switch between vertical and horizontal but that rotates all the pieces on a sheet and does not take advantage of saving only rotating a few pieces can achieve.
If you have \"Grain\" checked on your material Glenn, nesting won't rotate the parts regardless of the nesting orientation.
here's an example of mixed rotation nesting of parts without grain.
nest no grain.jpg (93.79 KiB) Viewed 13272 times
