Greg,
You will need to find the directory that your jobs are saved in. Mine is in C/eCabinets/Jobs
When you find the directory you locate the job. It will be Your Job.esj
You can right click and copy the job and then go to the location of your removable drive which is probably My computer/ whatever drive
You can most likely right click on the job and then choose Send To and then select the drive.
After copying the job files transfer the drive to the laptop then locate the drive and copy the files and place them in the laptop eCabinets/Jobs file.
