transfering job files to a laptop
Greg McCorkill
What is an easy way to transfer job files from my desktop to my laptop for presentations?
- Dean Fehribach
- Site Admin
Re: transfering job files to a laptop
I realize that Gene's response seems obvious, but that's what I'd do, too, based on the wording of your OP.
Dean Fehribach
I.S. Mgr., Thermwood
Greg McCorkill
how do you get the file onto the memory stick?
- DanEpps
- Company Name: Dan Epps
You copy it from the appropriate eCabinets directory.
- Kerry Fullington
Re: transferring job files to a laptop
Greg,
You will need to find the directory that your jobs are saved in. Mine is in C/eCabinets/Jobs
When you find the directory you locate the job. It will be Your Job.esj
You can right click and copy the job and then go to the location of your removable drive which is probably My computer/ whatever drive
You can most likely right click on the job and then choose Send To and then select the drive.
After copying the job files transfer the drive to the laptop then locate the drive and copy the files and place them in the laptop eCabinets/Jobs file.
