Placing door:
leigh mills
Placing door:
Post by leigh mills »
Hi guys,
i have a 30 degree angled wardrobe which i now need to place a door, when i come to place the door, the door will be straight which means it doesnt go flush to one side. Is there a way to angle a door or is there another way of creating the cabinet to suit an angled door if i cant angle a door. thanks
leigh
Re: Placing door:
Instead of adding the door in the Door/Drawer Editor, add it manually in the same way you would a cabinet...click the Load Item icon and select Door. You will have to manually size the door but you can orient it any way you wish.
leigh mills
Re: Placing door:
i have just tried this way dan, it lets open a atandard door but the doors in which i have created and saved cannot be opened as it says "select a Door"
Re: Placing door:
Leigh,
After selecting Doors/Drawers in Place Item click on the Select Door Button to open up the Door Drawer Editor to select a door you have created.
leigh mills
Re: Placing door:
yes this is what i have done, it only lets me open the satndard doors and not the ones in which i have created
Re: Placing door:
You don't see something like this?
door selection.jpg (34.84 KiB) Viewed 5927 times
You should be able to find any door you created by browsing to the directory you saved it in.
leigh mills
Re: Placing door:
This is what i get yes. i then select the door that i have saved and then it is shown up below select door in the door drawer option, when i then click ok it says select a door, which i already have. But when i select another door which isnt located in my own directory it will be loaded up.
