Hello,
I am working on a project fabricating retail display units for a door hardware distributor. I have designed the display unit as an assembley of basically 3 boxes, a base, a top and a column. I am fabricating in batches of 5-8 units.
When I go to "Batch Cabinets and select the assembly and alter the number of units from 1 to 8, and then proceed to "nesting", when I check the filter, only one unit will be nested. I even tried entering 8 units manually. The number units showing in the window in the Batch cabinets area shows the count going to 8, but yet still ony 1 unit nested.
Any help would be apreciatated.
Emanuel Leimanis
Leimanis Cabinetry & Millwork Ltd
Batch Cabinet problem
Emanuel Leimanis
Emanuel Leimanis
Urban Country Woodworking
Justin Melhiser
Re: Batch Cabinet problem
Emanuel
Send me your .esa files. I will need to load it here and see if I can reproduce it.
Emanuel Leimanis
Hi Justin,
Thanks for your response. Where should my esa. files be located and which ones do you need?
Emanuel Leimanis
Emanuel Leimanis
Emanuel Leimanis
Justin Melhiser
Emanuel
I am sorry, I do not need the esa file I need your cabinet file you are trying to load. You can find these files under your ecabinets directory in the windows explorer. It will be located under the assemblies folder.
