Hello,
I am working on a project fabricating retail display units for a door hardware distributor. I have designed the display unit as an assembley of basically 3 boxes, a base, a top and a column. I am fabricating in batches of 5-8 units.
When I go to "Batch Cabinets and select the assembly and alter the number of units from 1 to 8, and then proceed to "nesting", when I check the filter, only one unit will be nested. I even tried entering 8 units manually. The number units showing in the window in the Batch cabinets area shows the count going to 8, but yet still ony 1 unit nested.
Any help would be apreciatated.
Emanuel Leimanis
Leimanis Cabinetry & Millwork Ltd
Batch Cabinet problem
Emanuel Leimanis
Urban Country Woodworking
Re: Batch Cabinet problem
Emanuel
Send me your .esa files. I will need to load it here and see if I can reproduce it.
Hi Justin,
Thanks for your response. Where should my esa. files be located and which ones do you need?
Emanuel Leimanis
Emanuel Leimanis
Emanuel Leimanis
Emanuel
I am sorry, I do not need the esa file I need your cabinet file you are trying to load. You can find these files under your ecabinets directory in the windows explorer. It will be located under the assemblies folder.
