Mastercam V9.1 problem
Recently Mastercam v9.1 was moved onto my account from another account on the same computer, now I'm unable to "Import sheets from nesting session" and under the parts tab I can't "Save list as library" or "Load part library". I've also tried to create a new sheet and then export it to a library but all these options are grayed out... Any suggestions?
Re: Mastercam V9.1 problem
Adam,
You may need to run the MasterCam HASP update while you are logged on to your new acct. If this doesn't work and if you have purchased your Mastercam software through Thermwood corporation, please contact program@thermwood.com for additional info.
Which HASP update would I need to run? The one that was for SP2? Sorry, I'm kind of new to this.
The HASP update comes directly from MasterCam Dealer. If you purchased MasterCam through Thermwood Corp., I will need to know you company name in order to retreive the code for you. If you did purchase your MC software through Thermwood, you can email program@thermwood.com for further details regarding this update.
