Lamar Horton wrote:Thanks again,
I was afraid to move stuff around again but that worked. I know have my libraries back. I am happy now. As far as that Conestogaz folder is concerned, I won't be going any where near it again!!!
Yeah...drop it like its hot!
Now that you have everything back in place and running,
MAKE A BACKUP!!! If you're not already in the habit of doing regular backups in eCabinets (File - Backup My Files), this is a great time to start. That will give you a copy to restore in case something like this ever happens again.
You have probably already noticed that all of your materials and settings are gone too. The eCabinets backup will copy those files also. If you still have the original files from before you reinstalled, you can copy eCabinets.mdb and eCabinets.ini to the new installation directory and that will restore your materials and settings.
If you are unsure whether those files are the originals, check the size of eCabinets.mdb. If it is the copy with all of your materials in it, it will be larger than the one you just installed.
