Unrecognized database format
Lamar Horton
What is this error message?
"Unrecognized database format 'C:\Program files"\Thermwood\Ecabinets System\Doors\Conastogaz\zigaba.twt"
Lamar Horton
http://www.jlcustomcabinets.com
- DanEpps
- Company Name: Dan Epps
Re: Unrecognized database format
The Conastogaz directory contains licensing files. If you have altered the contents of the directory in any way (this includes moving or copying) it will cause the license to no longer be recognized.
There used to be a license reset utility the eCabinets folks could send you but, since this is Saturday...
I'll search through the forum and see if I can find any referrence to it.
- DanEpps
Well, I searched through the forum and couldn't find any references. Of course, my memory of seeing it could be faulty.
Lamar Horton
Thanks Dan, I couldn't find anything either.
Since then I have gone from bad to worse. It all started when I tried to print my nesting sheets and it locked up. Upon restarting ecabs, I started getting this error. That's when I started thinking, me being a rocket scientist and all and that I knew what I was doing by moving stuff, deleting stuff, moving stuff back, restoring stuff. Well that only made things more better bad.
I uninstalled ecabs and tried to reinstall, now I get a message saying my version is expired call the calvary. So now I dead in the water till Monday I guess.
Probably for the better, my wife has informed me we are going out for dinner and maybe a movie tonight, leaving the children to forage for themselves.
Lamar Horton
Lamar Horton
All is almost well again. I removed build 5 and then reinstalled it . But know because I reinstalled the entire program I no longer have my libraries. When I did my reinstall, I renamed the thermwood folder so the reinstall would create a new directory. Is there any way I can migrate my old files into the new directory?
Lamar Horton
- DanEpps
As long as you didn't delete your libraries you can just copy them to the new install location. Just don't copy the Conastogaz directory!!!
Lamar Horton
Thanks again,
I was afraid to move stuff around again but that worked. I know have my libraries back. I am happy now. As far as that Conestogaz folder is concerned, I won't be going any where near it again!!!
Lamar Horton
- DanEpps
Yeah...drop it like its hot!Lamar Horton wrote:Thanks again,
Now that you have everything back in place and running, MAKE A BACKUP!!! If you're not already in the habit of doing regular backups in eCabinets (File - Backup My Files), this is a great time to start. That will give you a copy to restore in case something like this ever happens again.
You have probably already noticed that all of your materials and settings are gone too. The eCabinets backup will copy those files also. If you still have the original files from before you reinstalled, you can copy eCabinets.mdb and eCabinets.ini to the new installation directory and that will restore your materials and settings.
If you are unsure whether those files are the originals, check the size of eCabinets.mdb. If it is the copy with all of your materials in it, it will be larger than the one you just installed.
