I updated the CN this morning and ran in a problem. In front of every part, in the G-code, the CN throws a part information which is not completely in () which confuses the SuperControl. The error is invalid character in EIA block!!!
( Sheet: 1, Part: , Name: Right Hinge Double Door (Slab), Material: PL1_1SIDE)
Nemaja,
This is a known bug within Ecabinets having to do with the double (()) Parenthesis. This is carried over From Ecabs to CN thus causing the problem. This issue has been resolved in the latest build, which is going to be released very soon. The only work around at this time is to go into the NC code and delete the interior set of parenthesis.
The actual date for the release of the new update is close, but I do not know exactly when.
I never had that problem before (and i started with the CNC when the CN was still in single digits), till now.
To fix this i ran the repair on 5-38 and it works just fine. The option of deleting the line of code is unproductive, especialy if there is over 100 doors to be cut!!!
Nemanja Vujkovic wrote:I never had that problem before (and i started with the CNC when the CN was still in single digits), till now.
Nemanja,
You're right! I have spoken with the programmers and they fixed this on the ecabinets end for the next build.
Nemanja,
We should be releasing CN 5.40 today. It is not up yet, but I just tested it for this problem. This update should fix the issue you are having with the double parethesis when writing the code for doors. FYI
