CN 5-39 problem
Nemanja Vujkovic
CN 5-39 problem
I updated the CN this morning and ran in a problem. In front of every part, in the G-code, the CN throws a part information which is not completely in () which confuses the SuperControl. The error is invalid character in EIA block!!!
Todd Miller
Re: CN 5-39 problem
Nemanja,
What kind of parts are you running?
When I post out with 5.39 I get lines like this.....
( Sheet: 1, Part: , Name: Front Toe, Material: 3/4 Generic)
Is a line like this giving you the error? If not post a the line or lines giving you the problem.
Nemanja Vujkovic
Re: CN 5-39 problem
Hi Tod!
I was running doors!
It looks like this
( Sheet: 1, Part: , Name: Right Hinge Double Door (Slab), Material: PL1_1SIDE)
It looks like this
Todd Miller
Re: CN 5-39 problem
Nemaja,Nemanja Vujkovic wrote:Hi Tod!
It looks like this
This is a known bug within Ecabinets having to do with the double (()) Parenthesis. This is carried over From Ecabs to CN thus causing the problem. This issue has been resolved in the latest build, which is going to be released very soon. The only work around at this time is to go into the NC code and delete the interior set of parenthesis.
The actual date for the release of the new update is close, but I do not know exactly when.
Nemanja Vujkovic
Re: CN 5-39 problem
I never had that problem before (and i started with the CNC when the CN was still in single digits), till now.
To fix this i ran the repair on 5-38 and it works just fine. The option of deleting the line of code is unproductive, especialy if there is over 100 doors to be cut!!!
Todd Miller
Re: CN 5-39 problem
Nemanja Vujkovic wrote:I never had that problem before (and i started with the CNC when the CN was still in single digits), till now.
Nemanja,
You're right! I have spoken with the programmers and they fixed this on the ecabinets end for the next build.
Todd Miller
Re: CN 5-39 problem
Nemanja,
We should be releasing CN 5.40 today. It is not up yet, but I just tested it for this problem. This update should fix the issue you are having with the double parethesis when writing the code for doors. FYI
Nemanja Vujkovic
Re: CN 5-39 problem
Thank You Todd for the quick reply. I am looking forward to CN 5-40!!!
Todd Miller
Re: CN 5-39 problem
Nemanja,
Here is a link to the CN update (V5.40).
http://downloads.thermwood.com/ControlNesting5-40.exe
Nemanja Vujkovic
Re: CN 5-39 problem
Thank you Todd!!!
