Cabinet Moldings
Sergio Fetter
Company Name: Two Mile
Cabinet Moldings
Post by Sergio Fetter »
Hello everyone,
I am working on my first really fancy kitchen layout. I have encountered some problems in placing moldings.
What is the best way to do that? Would you install molding in the cabinet editor, even if there are just on the side of the cabinet? Or would you install molding after the cabinets are in place?
I have had a time trying to install my molding in the cabinet editor. The molding is either to long, or too small. How much editing can I do to a molding once it is placed in the cabinet editor? I know I could take to the part editor. But can I resize there?
Could someone help me.
Thanks!
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Re: Cabinet Moldings
Hi Sergio
I like to put them on in the cabinet editor
Molding Settings.jpg (85.59 KiB) Viewed 3974 times
Molding Settings 2.jpg (89.83 KiB) Viewed 3974 times
Add on moldings
1-24" Baseboard
1-24-3/4" Crown
1-24" x 1-1/2" x 3/4"
Molding Settings 3.jpg (80 KiB) Viewed 3954 times
Sergio Fetter
Thanks George,
Those picture are great. I like the idea of using the modling editor, because if you have to change the size of the cabinet the molding changes size as well. Will that be a problem if you have molding for individual cabinets? In other words would that mess it up all this single moldings for each cabinet instead of a whole piece?
Also how did you get that molding to fo around outside the cabinet?
Once again, thank you very much!
Sergio Fetter
Designer Specialist
