DRAWER BOX ERROR
jerry johnson
DRAWER BOX ERROR
Post by jerry johnson »
Could someone at Thermwood look at this file and tell me what is wrong? The mortise machines properly but the tennon is too thin. Thanks in advance!
apple .485 prifinished 230 box .5 bottom.hsf
(52.02 KiB) Downloaded 505 times
8)
Larry Epplin
Re: DRAWER BOX ERROR
Post by Larry Epplin »
Hi Jerry. We have located the problem. Sorry for the inconvenience. We plan to have a patch available to fix the problem. I can not give a time when the patch will be available yet. We are working as diligently as possible. We appreciate your patience.
jerry johnson
Thanks, Larry.
David Hall
Post by David Hall »
Same problem here.
According to the ecabs nest (and a sheet of drawer parts on its way to the dumpster)
It appears that when you change the tenons to greater than 50% thickness, the dados change in width, but most of the tenons remain at 50%.
50% thickness seems like it would work.
Dave
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
