Placing a Rectangle on a Wall
Joe Dusel
Post by Joe Dusel »
I'm having problems placing a rectangle on a wall. I created a wall 108" high and 144" wide. I want to create a hole in it. I'm starting the rectangle at 24,24. I then select INC. If I enter a whole number or decimal number value all is well, and the rectangle is created properly. If I use fractions the rectangle is not the right size. The numbers I entered were 24 1/2,24 1/2 for the incremental X and Y values. (Actually, the numbers don't seem to matter.) Is there a special way to enter fractions? This would appear to be a bug, but maybe it's operator error.
creating rectangle 2.jpg (66.8 KiB) Viewed 3612 times
creating rectangle.jpg (27.72 KiB) Viewed 3612 times
Re: Placing a Rectangle on a Wall
I ran into a similar situation during beta testing Joe...you have to enter the annoying inch symbols (").
Joe Dusel
Post by Joe Dusel »
Thanks Dan, but I must be extra thick. Can you splain it to me? When I enter the inch marks I just get error messages if they are included with fractions.
create rectangle3.jpg (85.5 KiB) Viewed 3551 times
Hmmm...I have my display dimensions set to inches and decimals so that may account for the need for the inch symbol.
Try entering 24.5" instead of 24 1/2" and see if that works.
Joe Dusel
Post by Joe Dusel »
Thanks Dan,
Inches and decimals works without a problem - even without the inch (") mark. It's just the fractions that have the problem as far as I can see. I can work around this of course, but it does seem like there are two bugs here - the first is the problem entering fractions and the second is the error message that pops up when you enter the inch symbols.
