Is there any way to get the line drawing editor to print the room layout larger?
On a normal sheet of paper the image is measuring 2 1/2" X 2 1/2"
LDE
- Gary Puckett
LDE
Justin Melhiser
Re: LDE
In the LDE the rectangle on your screen represents the paper size your printing to. If you click on the room icon at the top left and select your room, you can zoom in and out to make it larger and smaller to where it will fit inside this rectangle. If it is outside the rectangle it will not print on the paper.
- Gary Puckett
Re: LDE
Justin
Thanks , in the LDE there is a tool tap and it has a sub tab of drawings. When you create a cab. in cab editor does it automaticly make a dim. drawing in the LDE?
