In the LDE the rectangle on your screen represents the paper size your printing to. If you click on the room icon at the top left and select your room, you can zoom in and out to make it larger and smaller to where it will fit inside this rectangle. If it is outside the rectangle it will not print on the paper.
Thanks , in the LDE there is a tool tap and it has a sub tab of drawings. When you create a cab. in cab editor does it automaticly make a dim. drawing in the LDE?
