I can not get the top of this corner base into the part editor.Also tried the sides and back.This is the message I get.I did load a base cabinet and it went to the PE just fine.
ScreenHunter_02 Aug. 06 14.46.gif (8.62 KiB) Viewed 3446 times
The cabinet has lost some of its bodies to restore them do this. Select the cabinet then select –remove part editor cuts – from entire cabinet from the mouse tire. I’ll look in to this and see what I can come up with for why this happened. Sorry for the inconvenience
Scott
Are you still running v5.1build 4 for ecabinets? That’s the version history of this cabinet for the last time it was saved. The problem may have already been fixed in one of the newer versions but ill look at it to make sure.
