Gary Puckett
Posts: 1324 Joined: Mon, May 19 2008, 1:39PM
Company Name: The Woodworkery
Post
by Gary Puckett » Sat, Sep 27 2008, 9:40AM
Does anybody know how to get sinks from Kohler to place in the drawing?
Joe Dusel
Posts: 1117 Joined: Tue, May 17 2005, 9:40PM
Post
by Joe Dusel » Sat, Sep 27 2008, 9:04PM
Go to Kohler's web site and download. You will then need to convert it to an STL to import it into eCabs through the Display Part Editor.
http://www.us.kohler.com/tech/cadsymbol/cadsymbol.jsp
Is there one particular one that you need in case one of us has it?
CFT411
http://www.cft411.com
Intel i7 920 @ 2.67GHz, 6 GB RAM,
Windows 7 64 bit , NVIDIA Geforce GT220 (1GB)
Gary Puckett
Post
by Gary Puckett » Sat, Sep 27 2008, 9:17PM
I did get it converted to a stl, but when I gave it texture it came out with hatch marks. Here is the sink
kohler sink.K-227.stl
(686.08 KiB) Downloaded 463 times
Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Sat, Sep 27 2008, 9:47PM
Hi Gary
Joe Dusel
Post
by Joe Dusel » Sat, Sep 27 2008, 9:55PM
What is the model number for this sink so I know what it's supposed to look like?
CFT411
Gary Puckett
Post
by Gary Puckett » Sat, Sep 27 2008, 10:57PM
Joe,
It's K-2217
Joe Dusel
Post
by Joe Dusel » Sat, Sep 27 2008, 11:15PM
Hi Gary,
I see what George sees, and it looks like what is on the Kohler site. I guess I'm kind of confused as to what the problem is that you are having.
CFT411
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Sun, Sep 28 2008, 8:42AM
Gary,
I tried it also and using the gourad setting it looks fine . The only problem I see is the cross hair look in the center of the sink but that is a problem in the original model and it doesn't bother me enough that I wouldn't use it in a presentation.
Gary Puckett
Post
by Gary Puckett » Sun, Sep 28 2008, 9:03AM
I went to the Kohler site and copied the color skyblue for the sink and this is what I get.
Kohler Sk.jpg (53.12 KiB) Viewed 7687 times
Post
by Kerry Fullington » Sun, Sep 28 2008, 10:43AM
Gary,
It is tiling the image instead of stretching it. Just use the color controls in the Display Part Editor to get your color instead of using the image. You can also find many colors in the Formica and Wilsonart folders using the Display Part Editor.
Joe Dusel
Post
by Joe Dusel » Sun, Sep 28 2008, 11:27AM
Did you crop the image before using it? If you did not I''m assuming the pattern you are seeing is the border of the image you used. I would just try setting up the colors to get close to what you need.
CFT411
Gary Puckett
Post
by Gary Puckett » Sun, Sep 28 2008, 12:24PM
Thanks Kerry & Joe for all your help. It's just when a problem happens I need to find out why.
I know that there is always a way around a problem to get to the end result.
