ScotAcree
Posts: 101 Joined: Mon, Aug 08 2005, 6:06PM
Company Name: Scot Acree Woodworkig LLC
Post
by ScotAcree » Wed, Oct 29 2008, 8:48AM
Could someone try to open this job and run a cost report?Mine shuts down when it gets to calculating sheet goods.
Scot
test1.zip
(5.54 MiB) Downloaded 522 times
Justin Melhiser
Post
by Justin Melhiser » Wed, Oct 29 2008, 2:06PM
Scott
I am looking at your file now and will let you know.
ScotAcree
Post
by ScotAcree » Wed, Oct 29 2008, 2:56PM
Justin,
Let me know if you need more info.
Scot
Justin Melhiser
Post
by Justin Melhiser » Thu, Oct 30 2008, 8:22AM
Scot
There is a cabinet that you can not see in your room. See image below. You should be able to click where this cabinet is and delete it. If you need it in there then change the sheet stock in the room, just select the same material for each one. This will reginerate all the cabinets and the hidden cabinet will now be in view. This will allow you to create your cost sheet.
hidden cabinet.JPG (14.27 KiB) Viewed 4879 times
ScotAcree
Post
by ScotAcree » Thu, Oct 30 2008, 9:11AM
Justin,
Works like a charm,thank you for finding this.Lesson learned.
Great service Thermwood Team.
Scot Acree Woodworking,LLC
