Hinge
Wally Schneeberger
Hinge
Post by Wally Schneeberger »
Dimensions for hinges are different from one gable to another. The cabinet uses the same settings so how come?? Anyone have some ideas on this one?? TIA
Re: Hinge
Post the cabinet and someone can look at it Wally.
Wally Schneeberger
Re: Hinge
Here's the file.
BCC36.hsf
(640.02 KiB) Downloaded 434 times
Re: Hinge
If you nest the cabinet, it looks like the right end has the hole pattern twice.
Wally Schneeberger
Re: Hinge
Rick Palechuk wrote:If you nest the cabinet, it looks like the right end has the hole pattern twice.
Thanks Rick -- You reminded me that there was originally hinge holes on the right gable done in the PE. I removed these and everything is good to go.
