Don Nichelson
Posts: 65 Joined: Thu, Aug 24 2006, 1:49AM
Post
by Don Nichelson » Tue, Dec 02 2008, 3:32AM
I have a kitchen designed already and needed to add crown molding to it. Is there a way to add crown in custom layout or do I have to take each cabinet individually and edit them? What is the fastest way to do this?
Posts: 5852 Joined: Thu, Jul 28 2005, 10:18AM
Post
by DanEpps » Tue, Dec 02 2008, 7:03AM
One easy (and resizable) method is to create a new cabinet with all parts except the top removed. Add crown molding to it and save as a cabinet.
You can now add that cabinet to a room layout and resize as necessary. After you add it just move it into location on top of the cabinets.
Don Nichelson
Post
by Don Nichelson » Tue, Dec 02 2008, 12:06PM
Dan, could you explain how to do this in more detail? I am not sure what you mean by taking the cabinet without the tops.
Post
by DanEpps » Tue, Dec 02 2008, 12:29PM
Only the top, not "without the tops."
Open a standard upper cabinet in the Cabinet Editor. Go into Construction Settings and uncheck the "Has..." box for every part except the top.
Exit Construction Settings and you have a cabinet that consists of only a top. Add your crown to is and save as a new cabinet.
Resizable Crown.jpg (3.91 KiB) Viewed 3923 times
Resizable Crown.hsf
(74.02 KiB) Downloaded 362 times
