Moving Cabinet
Sergio Fetter
Company Name: Two Mile
Moving Cabinet
Post by Sergio Fetter »
Hello everyone,
I am working on my first job in the 5.2 build 3. I am encountering some problems.
I am trying to place a a sink cabinet. Once I pick it, I change the size from 36in to 33in and click ok. The closest that I can get to my corner cabinet is 2in. That causes a problem in my layout. If I click to go to the left (opposite) the cabinet jumps to the door of the kitchen.
Has anyone else have had this problem? Does anyone have any idea on what I should do?
S Fetter
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Justin Melhiser
Re: Moving Cabinet
Post by Justin Melhiser »
Sergio
Right click on your screen int he room layout. Go to define standard dimensions. Check the cabinet to cabinet clearance, make sure this is not set to 2". If it is change it to 0" and it will work fine.
Sergio Fetter
Re: Moving Cabinet
Justin,
Thank you very much for your quick reply. I have that set and still will not work.
Here I am attaching my job there so you can check it out.
WW_2BED.esj
(3.6 MiB) Downloaded 601 times
Sergio Fetter
Designer Specialist
Walker T Scott
Re: Moving Cabinet
Post by Walker T Scott »
Sergio
You will have to make the two cabinets an assembly for what you are trying to do. I have attached a modified version of your room. Hope this helps.
WW_2BEDMOD.esj
(3.76 MiB) Downloaded 515 times
Justin Melhiser
Re: Moving Cabinet
Sergio
That is not a corner cabinet that your trying to place the cabinet next to, this is why it will not snap to its edge. I deleted your cabinet and made sure mine cabinet to cabinet was set to zero, zoom in on the area I wanted to install the cabinet and it installed fine. You can also try changing the place mode to free style and add the cabinet.
Sergio Fetter
Re: Moving Cabinet
I appreciated that Walker.
I guess that will solve my problem for the time being.
Thanks again!
Sergio Fetter
Designer Specialist
Sergio Fetter
Re: Moving Cabinet
Justin,
Thank you very much.
How would you define a corner cabinet. I need a cabinet in that shape and there is nothing like in the standard cabinets.
Could you give me couple hints to make a corner cabinet in that shape that will snap?
Thanks!
Sergio Fetter
Designer Specialist
Justin Melhiser
Re: Moving Cabinet
Sergio
Take a look at this cabinet. It started out as a corner cabinet.
Sergio Fetter
Re: Moving Cabinet
Hey Justin,
It looks good. Is this a base cabinet or wall cabinet? Can I add frace frame to it?
Thanks!
Sergio Fetter
Designer Specialist
Justin Melhiser
Re: Moving Cabinet
Sergio
This is a base cabinet detached toe and yes you can put face frames on it.
