5.2 build 3 problems
I loaded 5.2 build 3 and am having a lot of problems. In the LDE I cannot go from page to page, when I take a cabinet into any of the editors the face frame and doors are all there and not transparent so I cannot see the inside of the cabinet to move partitions or shelves, modify or add drawers etc.. Also, I am getting all kinds of holes for drawer slides in all kinds of wierd places. HELP!!
Thanks!
Thanks!
Re: 5.2 build 3 problems
I am having a problem with the LDE also. I bring the drawing into the LDE and if I change the page it is blank, if I go back to the page I just brought in it is now blank.
I am not having the problem in the other editors. When I first upgraded I had it, I just re started the program and it went away. Just checked again and it is not happening, still good. But the LDE blank pages problem is still happening.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
- Jean G Voyer
I have the same problem with the LDE with blank pages. But I tried to delete a page and it reappeared asking me if I wanted to do it or not. Until that everything is blank.
Jean-Gabriel Voyer
Janot Interiors Ltd
www.customcabinetscalgary.com
Janot Interiors Ltd
I can confirm that it comes back when you go to delete it. But it'll disappear again when you switch pages. Inconvienient, but workable for now.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Jerry
Could you attach the job and will take a look at it.
Leo and Jean
Im getting the same thing and have passes this on to the programmers.
Leo and Jean
Leo and Jean
Here’s an easer work around minimize then maximize the ecabinets window. This should bring every thing back.
I saw another interesting problem last night on a system using Vista. For some reason the eCabs software would not recognize any of the directories in the Cabinets folder when using the Cabinet/Assembly Editor. It recognized the Assemblies directories. I checked that the directories and files were there using Explorer. I then copied the Cabinets directory into a backup directory and did a Restore from it. The Cabinets directories then showed up again. Very strange...
CFT411 http://www.cft411.com
I ran "restore my files" and all seems to be well.
Mine just seemed to sort itself out. Seems to work fine.....for now.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
OK I have a new one. Same place, LDE. I took a wall into the LDE and it showed me the backside of the wall. It took me a minute to figure out what this square was that was on the screen. I had to rotate it 180* to get the view that I wanted and should have been shown. Nothing critical, just another weird bug. My wall is facing the correct way, I tried reversing the build, but it just screwed everything up.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Leo
Are you taking a reverse build wall to elevation view then taking it to the LDE? If so this is a known issue, if this is not what you are doing could you elaborate a little more of what you are doing.
This is not a reverse built wall. I go from the room editor into the single wall display in the room editor, wall #2 in my case. Then I choose the LDE icon and it gives me a series of choices and I choose take wall into LDE. When it takes the wall it is showing the backside of it which is blank. I have to rotate it 180* to get to the correct side. If this is a known problem I apologize for bringing it up again, it is a new problem to me and I don't recall seeing it on the forum. Thanks for the help.
If you need the file I can send it up.
Leo
Leo
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Could you attach the job and ill take a look and pass it along to the programmers.
Can't get it to uplad as an attachement. What is the email address please.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
We have a client that has noticed since the update that doors size are not setup to 1/64" .
This is trowing his guys off when making or ordering doors.
I am assuming that they are setup in their preferences to inches and fractions.
As anyone seen this?
