5.45
- Company Name: Plett Roofing
- Country: SOUTH AFRICA
Good morning
Install Control Nesting v5.44 at the end of last year and everything was a mess. Did a system restore to go back to 5.41 and everything back to normal. When we re-open on Monday I see that there was a 5.45 available and install that, everything seem fine until this morning when I want to cut a simple part that I have created with eCabinets (a square part with a simple cut-out). The machine ramp in where the cut is and then cut into the part itself.
I have included the .twd file.
Must I reinstall 5.41?
Thanks in advance
Marius
Thanks in advance
Marius
- TURNER.zip
- (1.13 KiB) Downloaded 538 times
Re: 5.45
Ok
Just tried to cut two partitions with dado's and the same thing happen. The machine ramp in at the dado then cuts into the part by more or less the radius of the cutter, then it reverse (back track) and then carry on by cutting the part.
I have again included the .twd file.
- MEREDITH.zip
- (1.03 KiB) Downloaded 498 times
Re: 5.45
Marius,
The CNC files ar the only things that you have attached. I would like you to send me the export information from your machine, along with the .hsf (cabinet) file from ecabinets.
To get the export information from the machine....
First, open Control Nesting.
Then, click on the "EXPORT" button in the lower right-hand corner.
Save the file to your desktop and attach the .CAB file to the email along with the .hsf file from ecabs.
Send to program@thermwood.com
Re: 5.45
Good morning Todd
I have zipped everything for you and will e-mail it to you now.
Ja, I have post the .cnc files and not the .twd files stupid me.
Thank you very much
Marius
Thank you very much
Marius
Re: 5.45
Good afternoon Todd
Thank you, and all the people working on this to solve the problem.
Glad my company made the right choice when they bought this cnc machine.
"Thermwood is bakgat"
Re: 5.45
Marius,
The update is availiable for download. Here is the link.
http://order.ecabinetsystems.com/update ... ng5-46.asp
