5.45
Marius Gouws
Company Name: Plett Roofing
Country: SOUTH AFRICA
Post by Marius Gouws »
Good morning
Install Control Nesting v5.44 at the end of last year and everything was a mess. Did a system restore to go back to 5.41 and everything back to normal. When we re-open on Monday I see that there was a 5.45 available and install that, everything seem fine until this morning when I want to cut a simple part that I have created with eCabinets (a square part with a simple cut-out). The machine ramp in where the cut is and then cut into the part itself.
I have included the .twd file.
Must I reinstall 5.41?
Thanks in advance
Marius
TURNER.zip
(1.13 KiB) Downloaded 588 times
Marius Gouws
Re: 5.45
Ok
Just tried to cut two partitions with dado's and the same thing happen. The machine ramp in at the dado then cuts into the part by more or less the radius of the cutter, then it reverse (back track) and then carry on by cutting the part.
I have again included the .twd file.
MEREDITH.zip
(1.03 KiB) Downloaded 549 times
Todd Miller
Re: 5.45
Post by Todd Miller »
Marius,
The CNC files ar the only things that you have attached. I would like you to send me the export information from your machine, along with the .hsf (cabinet) file from ecabinets.
To get the export information from the machine....
First, open Control Nesting.
Then, click on the "EXPORT" button in the lower right-hand corner.
Save the file to your desktop and attach the .CAB file to the email along with the .hsf file from ecabs.
Send to program@thermwood.com
Todd Miller
Re: 5.45
Marius,
Could you also take a picture of the cut that was made. This would give me a better idea of what is happening. Thanks.
Marius Gouws
Re: 5.45
Good morning Todd
I have zipped everything for you and will e-mail it to you now.
Ja, I have post the .cnc files and not the .twd files stupid me.
Thank you very much
Marius
Todd Miller
Re: 5.45
I did receive your files. Thanks Marius.
Todd Miller
Re: 5.45
Marius,
The update to fix this issue will be released sometime today. FYI
Marius Gouws
Re: 5.45
Good afternoon Todd
Thank you, and all the people working on this to solve the problem.
Glad my company made the right choice when they bought this cnc machine.
"Thermwood is bakgat"
Todd Miller
Re: 5.45
Marius,
The update is availiable for download. Here is the link.
http://order.ecabinetsystems.com/update ... ng5-46.asp
