Need Help Creating tool
I need help creating a tool in the shape manager. I drew the outline in my CAD program, but I keep getting an error "invalid argument". The DXF file was drawn with arches and lines. I made sure everything was closed numerous times. I just can't seem to get it to work.
Brian Shannon sent me a copy of his .tol that he created for a bar rail. Does the it make a difference if it is a inside or outside radius. I am going to attach the piece that I was trying to profile.
How do I attach the profile for the tool.
Zach
Zach
- Sunill_Bar.zip
- Bar Layout
- (81.99 KiB) Downloaded 736 times
Lyndan Designs
Machining and CAD Services
Re: Need Help Creating tool
Creat a .zip file of your .dxf tool file and you can attach it on the forum. I do not think it matter if its inside or outside radius.
Here is the profile of the tool
Zach
Zach
- barrail_tool.zip
- Tool Profile DXF
- (716 Bytes) Downloaded 758 times
Lyndan Designs
Zach
Can you post your steps from start to when you get this message? I loaded and created your tool just fine.
What radius are you trying to edit?
I believe that this is what you are trying to do. It's looking a little off, but i did not pay hole lot attantion to it. I only spend couple minute to do it.
- sunill_bar.zip
- (1.29 MiB) Downloaded 719 times
Justin,
I drew the file up in my cad program, saved it as a DXF, opened up the DXF in the shape manager, and tried to create the tool. I trimmed and made sure everything was closed. If you opened up the zip file with the tool profile, that is exactly what it looked like in the shape manager. I tried different mods of the same profile and kept getting the same error. I even went back and looked at other members .tol files to see if I was drawing it wrong.
Thank you guys for the help. I now have something to give to the builder to show the customer.
Zach
That is what I was looking for. I still don't understand why I was having such a problem creating the tool.Nemanja Vujkovic wrote:I believe that this is what you are trying to do. It's looking a little off, but i did not pay hole lot attantion to it. I only spend couple minute to do it.
Zach
Lyndan Designs
I am glad i could help. Good luck with the project.
- Jody Wilmes
- Company Name: Thermwood
When creating DXF files in a different software, make sure your drawing depth is at zero. For example: a dxf file that is drawn 1" above/below the origin will cause various problems.
