Grain on / off
Rob Davis
Grain on / off
Post by Rob Davis »
This is not a big deal but would be nice if it were easily accomplished....
Is there a way to turn the grain on or off for selected parts of a cabinet. For example, We really do not care which way the grain goes on toe kick boards since they get covered anyway, or top stretchers, etc. If we could turn the grain on or off for these parts then the router could nest them more efficiently on the sheet and put them in where ever they fit regardless of grain direction.
Is this already in the software somewhere and I jsut don't know it? I know it exists in the material set up region as well as you can rotate grain in construction settings but I do not see if you can tell it "I don't care which way the grain goes" for any one part of a cabinet.
Rob
Thom Davies
Company Name: Dawn Group
Country: NEW ZEALAND
Re: Grain on / off
Post by Thom Davies »
Rob
You can change the grain direction. from 0 to 179 degrees
Jeremy Schiffer
Re: Grain on / off
Post by Jeremy Schiffer »
Thom,
What Rob is asking is if it's possible to have eCabs mark those parts so CN will ignore the grain direction and therefore rotate them automatically for best yield. I've thought about this before and believe it'd be a very useful addition. Anyone else think this would be handy?
CS-41 4x8
CS-45 5x12
Michael S Murray
Re: Grain on / off
Post by Michael S Murray »
Id throw in my 2 dollars for that one also......
Mike Murray
mike@versatilecabinet.com
Rob Davis
Re: Grain on / off
Post by Rob Davis »
Jeremy & Mike,
I guess us 3 are the only ones who like this idea. I am going to put it on the "suggestions" board to do exactly what Jeremy said. I am often tossing out chunks of plywood that could be used for parts that are not grain sensitive (toe boards or whatever). I just think this would not be that hard to do but would save real money in material costs with immediate payback.
Michael S Murray
Re: Grain on / off
toe kicks, strechers, MAYBE even backs in base cabs, who actually gets down and looks at the grain direction on backs of base cabs,espescially a drawer stack! I use bunks of clearcote maple plywood and I definetly could see a savings with that material in particular.
I will post this as a suggestion also, see if we cab get a Hmmmmmm out of them..... :D
Mike Murray
Joe Soto
Re: Grain on / off
Post by Joe Soto »
I would like to see that added too.
Rob Davis
Re: Grain on / off
Post by Rob Davis »
Thermwood,
Can I suggest again this be added to the next version list of desirable enhancements? If this is easily done, it would have an immediate impact on the efficiency of using materials and profitability of the members actually cutting out parts on a router or as cut list. I am uncertain the difficulty but it seems a simple thing that has very tangible results.
I know you get peppered with lots of requests, but just asking for consideration.
Thanks for all you do for us already.
Re: Grain on / off
Post by Forrest Chapman »
Count me in and a few others I know of also as this has been suggested before.
MDF doors and parts!!!
