Cabinet End
Cabinet End
I am using detached toe kicks and it seems every now and again when I add a PO it will drop it the distance of the toe so I have some of it below the floor and down the same distance from the top of the cabinet
any idearrrs
any idearrrs
Iain Hall
Woodwright Cabinets
Woodwright Cabinets
Re: Cabinet End
I am guessing plant on,? applied end to us Dan..
Mike Murray
mike@versatilecabinet.com
Re: Cabinet End
I am guessing plant on,? applied end to us Dan..If I am wrong, I just made an Arse out of myself.......
Mike Murray
- DanEpps
- Company Name: Dan Epps
Re: Cabinet End
That makes sense then...I was thinking pullout and wondering how that could affect the detached toe.
Re: Cabinet End
Hey Ian, could you post an example to check out? It's probably an install height issue.
- Company Name: Creative Kitchens and Interior
- Country: NEW ZEALAND
Re: Cabinet End
I've had the same problem with applied ends.Sometimes it happens sometimes it doesn't.Drives me nuts so most of the time I add my applied ends as a display panel and associate it to the cabinet.Or if i add ends in CL I play around with the insets.Just did a job today with detached toes and had no problem adding them in CL
Re: Cabinet End
thanks for all of the info and yes PO does mean plant on for me I would use display panels more but I it seems that my wife has gotten a hold of my e Cab program, because when in cab edit I try to use the align function and it ignores me most of the time.
Iain Hall
Woodwright Cabinets
Woodwright Cabinets
