I am using detached toe kicks and it seems every now and again when I add a PO it will drop it the distance of the toe so I have some of it below the floor and down the same distance from the top of the cabinet
I've had the same problem with applied ends.Sometimes it happens sometimes it doesn't.Drives me nuts so most of the time I add my applied ends as a display panel and associate it to the cabinet.Or if i add ends in CL I play around with the insets.Just did a job today with detached toes and had no problem adding them in CL
thanks for all of the info and yes PO does mean plant on for me I would use display panels more but I it seems that my wife has gotten a hold of my e Cab program, because when in cab edit I try to use the align function and it ignores me most of the time.
