Corner cabinet construction
Phillip Fletcher
Company Name: Durham Bookcases
Post by Phillip Fletcher »
Concerning corner cabinets, I build mine differently than the program assumes. Ecabinets has every corner cabinets' tops, bottoms, and sides cut so that there is a variation in the surface depth (apparently so that the cabinet will fit together). I assemble mine in a different way than the program and I am not sure how to create a flat corner top.
Is there a way to restore the ledges that have been cut out of the tops or a default top that is cut like a corner but has no depth variation?
JohnLashuay
Re: Corner cabinet construction
Post by JohnLashuay »
Phillip,
Can you further explain your question?
You can change many different constraints using the "Construction Settings" button or just right click in the "Cabinet Editor" and click the "construction settings". In there you will find different tabs for each part of the cabinet.
Also, in the "global settings" tab you can change under "cabinet part construction" to different construction techniques.
I hope this helps!
-John
http://www.rylexonline.com
Thermwood CS 43
As John said, there are many settings for corner cabinets.
Corner Cabinet Settings are accessed by clicking the blue arrow (by the dimensions area) in the main Cabinet Editor screen.
Corner Settings 1.jpg (85.77 KiB) Viewed 3839 times
Construction Settings are as John explained.
Corner Settings 2.jpg (37.47 KiB) Viewed 3841 times
