I can not open the software
HELP I can not open the software I put the(Disk 5)_it came 8-13-08 and ran repair.
Here is what comes up.I did back up the hole file
Of all days I have to show it at 2:30 today They OK it put the Doc. wants to see it all in black.
Handicapped Cabinets_1.JPG (30.86 KiB) Viewed 3620 times
All the Cabinets_Handicapped_6-8-09.JPG (15.16 KiB) Viewed 3636 times
Larry Epplin
Re: I can not open the software
Post by Larry Epplin »
Hi George. You should run the latest update after a repair to insure all files are up to date. If it asks you to remove on the first try go ahead and do that. It does this because you have ran the update in the past. Then after the remove, run it again. That should get you going.
I Thank You Larry and the girls Thank You
The girl club.gif (156.01 KiB) Viewed 3583 times
Thank You again Larry
When I did the repair with the disk all I lost was the edge banding stock image on (generic) an I just put it back
