Knob/Pull Hole Pattern
Nat Wheatley
Post by Nat Wheatley »
Is there a way to associate a hole pattern with a knob or pull? I did a search of the archived posts a while back and didn't come across a method, but wanted to double check here also. Thanks.
Re: Knob/Pull Hole Pattern
Not that I know of.
Nat,
I think that has been on the wish list for added features for a while but not implemented yet.
Nat Wheatley
Thanks. It would be a nice feature, and save several steps. Hopefully they will add it.
Nat
Nat,
Be sure to go to Communications then Feedback and send this in to the programmers as an added feature request. Don't assume that Thermwood will see your request here. The more requests for a feature gives it a better chance to be added. (Squeaky wheel)
Nat Wheatley
Hadn't even seen the 'Communications' tab until now. Thanks!
Would this work for anyone
I made a DXF with holes lay ed out every 1/4" on the drawer up to 6" off the center
I started out with a base cab 24 x 34.5 x 24 with slad drawer I set my hole pattern to what I wanted. Then I can resize
the cabinet to the size I want to use.The holes stay in the center of any cabinet size
Try it
Drawer Holes.zip
(64.47 KiB) Downloaded 405 times
Drawer_20.75 x 6.7812.jpg (32.65 KiB) Viewed 5304 times
