Gary Puckett
Posts: 1324 Joined: Mon, May 19 2008, 1:39PM
Company Name: The Woodworkery
Post
by Gary Puckett » Fri, Jul 03 2009, 8:22AM
Is there a way to put a face frame with inset drawer fronts on the back of a cabinet without having to do it piece by piece.
Gary Puckett
Post
by Gary Puckett » Fri, Jul 03 2009, 8:43AM
Tried to copy and paste and that doesn't work
Posts: 1896 Joined: Wed, May 18 2005, 7:54PM
Post
by Rick Palechuk » Fri, Jul 03 2009, 9:22AM
Yes, develop a cabinet with a back made of 1/32" material, and depth of 25/32". Now you have a thin cabinet or "Bar Back" which is re-sizable. You can then add it to a cabinet and save as an assembly, or added directly to a room.
Gary Puckett
Post
by Gary Puckett » Fri, Jul 03 2009, 9:38AM
Rick,
How is that allowing me to take the back to the face frame editor and apply a face frame, then take that to door/drawer front editor and apply the inset drawer fronts
Post
by Rick Palechuk » Fri, Jul 03 2009, 9:49AM
Check out the Construction Settings Gary.
Std Base Framed test panel.hsf
(190.02 KiB) Downloaded 624 times
Std Base Framed test panel.jpg (14.79 KiB) Viewed 10822 times
Gary Puckett
Post
by Gary Puckett » Fri, Jul 03 2009, 9:55AM
Rick,
Went to construction settings and still don't get it, please explain it to me in steps
Post
by Rick Palechuk » Fri, Jul 03 2009, 10:06AM
I took a standard base framed cab to the CE I then removed the toe, sides, top and bottom. Changed the back material to 1/32 generic. Removed the adjustable shelf, set the depth of the cab at 3/4+1/32. Then in the DE removed the doors and drawer. Right click to construction settings, set the inset to 3/4 and the gap to 1/8 added the doors and drawer back. Back to main screen, and save. HTH
Post
by Rick Palechuk » Fri, Jul 03 2009, 10:09AM
If you download the Panel Gary, you can then inspect how the settings are configured.
Gary Puckett
Post
by Gary Puckett » Fri, Jul 03 2009, 10:21AM
Rick,
Sorry to be so thick headed, but here is what I am trying to do. This Cabinet is for a flat screen TV. The TV will be on a lift. I want to duplicate the front and put it on the back. So both the front and the back look alike.
Flat Screen TV Cabinet.zip
(346.99 KiB) Downloaded 693 times
Posts: 1261 Joined: Mon, May 30 2005, 2:26PM
Post
by Forrest Chapman » Fri, Jul 03 2009, 10:41AM
Gary,
Here ya go. It has to be made in an assembly which can only be resized in CE. All you have to do is double click to highlight each cabinet and resize individualy. I simply deleted all the parts except for the faceframe and then loaded the cabinet again. Then highlight one cabinet and rotate 180 degrees. You can then use the align item to lock the to cabinets together.
Flat screen TV Cabinet.zip
(633.16 KiB) Downloaded 685 times
Post
by Rick Palechuk » Fri, Jul 03 2009, 10:54AM
Gary, no need to apologize! I was under the impression that you needed a bar back.
Post
by Rick Palechuk » Fri, Jul 03 2009, 10:57AM
If you double click the cabinet, then you can copy it.
Gary Puckett
Post
by Gary Puckett » Fri, Jul 03 2009, 11:10AM
I am having a bad bad bad day, I down loaded the file from Forrest and when I go to open it it says it's an invalid file
Post
by Rick Palechuk » Fri, Jul 03 2009, 11:23AM
Did you unzip it first then save to your library?
Gary Puckett
Post
by Gary Puckett » Fri, Jul 03 2009, 11:25AM
Yes, saved it in my assemby file
