is it possible in ecabinets vertical bin
mohan kommineni
Company Name: ACRIFAB MANUFACTURING Pty Ltd
Country: AUSTRALIA
Post by mohan kommineni »
iam trying to design a vertical top opened bins with a adjustable shelf in it and ending up with problems can any one look at these file and give me a quick solution
the problems are
cannot put adjustable shelf in the place where i need(i want the adjustable shelf parallel to the back) shelf holes can be either on left-right ends or top-deck we have already wasted 2 days in just designing any help from ecabinets team or beta testers
iam in doubt where to start as there is no standard cabinet in the directory to my requirement and if i use the strecher instead of front and deck i am not getting the angle cut. pls look in to it and give a hint
VERTICAL BIN.esj
THE SHELF IS WRONG
(310.02 KiB) Downloaded 626 times
Bryan J Tanner
Company Name: Decor Designz
Re: is it possible in ecabinets vertical bin
Post by Bryan J Tanner »
Hi,
Most things are possible.
Is this what you are after?
I didn't put the shelf holes in, but they can be added in the part editor.
hope this helps.
VERTICAL BIN.esj
changed Job file
(310.02 KiB) Downloaded 689 times
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
Bryan,
I think you used the original file for your attachment, they both seem to be the same. :wink:
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
Mohan,
I am trying to picture what you want.... Seems that all you have to do is design the cabinet looking at the front (HOME view) as if you were looking down at it from the top. In this "view" the TOP would become your BACK, the DECK your FRONT,.. etc. You could add USER NAMES to the parts to clarify there function in this special cabinet.
As far as the orientation for placement into a Custom Layout -
Rotate the cabinet in the Cabinet Editor and then save it as an assembly. This will preserve the rotated orientation.
Hope this helps.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Brad McIntosh
Here is a quick example... The HSF and the ESA.
Vertical Bin.hsf
The Vertical Bin with Adjustamble "partions". (Concept)
(242.02 KiB) Downloaded 679 times
Adj. Vertical Bin.esa
ESA which preserves the rotation of the special cabinet.
(236.02 KiB) Downloaded 689 times
Brad McIntosh
CNC Automation
mohan kommineni
Country: AUSTRALIA
hi all thanks for ur replys but still i feel no one has got the way what i need,
some of u told to put the cabinet in front home view still iam alright with all of them but cannot get what i want.
let us use top bottom back deck strecher irrespective of name or view, what i want is shelf parallel to the cabinet opening can any one help me
as brayn said we can put the shelf but need to put the holes in the part editor i agree with him but in ecabinets can we copy a single circle multiple times but by using translate i dont think so and it takes long time to put shelf holes
but iam trying to give a go in this way
any ideas to solve it pls
Mohan,
Do you mean something like this?
Test Bin 1.hsf
(278.02 KiB) Downloaded 641 times
See if the holes work for you
I made 3/16" and 1/4" holes in DXF
Shelf Holes.zip
(87.81 KiB) Downloaded 681 times
.25 Shelf Holes.jpg (47.61 KiB) Viewed 12450 times
Cab
(2.1 MiB) Downloaded 710 times
Bryan J Tanner
:wall: :wall: :fire: :shock: :oops: :oops: :oops:
mmmmmm opps
though it looks like you guys have it in hand.
in my defence.... It was very late..... after a 16 hr day in the shop....... :cry:
HP Pavilion DV6
Dennis Englert
Post by Dennis Englert »
While there is not an array or translate function in eCabinets, the Move option provides a similar capabilities since it will copy an entity or entities along with the "move". A method that may make using this feature faster to use is to create a line from the center of the hole that is the length of the spacing between holes. Select the line and the hole to move with the copy feature selected and use the line as the translation points. It's actually pretty quick. Then mirror the holes about a "line" to create the second column of holes. The hole pattern can be copied using the "Create Edges" option in the Contour Mode for the holes needed on the opposite side.
Mohan,
Is this what you are trying to do?
Last edited by Kerry Fullington on Wed, Aug 19 2009, 7:42AM, edited 1 time in total.
mohan kommineni
Country: AUSTRALIA
Rick Palechuk wrote:Mohan,
thanks Rick
this is the design what i need, but still i cannot use it as i need angular faces on strecher and back when u use a strecther it dosent allow u to choose angular part or either i cannot cut a shape it it as i cannot bring it in to part editor
but when i make angle cuts on the left and right ends in PE it allows it but edge banding got problem cannot get rounded corners
any way rick with all u people suggestions and hints i have finished the design which iam uploading as vertical bin 1,shelf is not in the actual position when u see there but once manufactured it will fit exactly
thanks to one and all any fast way to do this pls suggest
VERTICAL BIN1.esj
shelf is ok after manufacturing,no problem in edgebanding aswell
(600.02 KiB) Downloaded 669 times
mohan kommineni
Country: AUSTRALIA
Dennis Englert wrote:While there is not an array or translate function in eCabinets, the Move option provides a similar capabilities since it will copy an entity or entities along with the "move". A method that may make using this feature faster to use is to create a line from the center of the hole that is the length of the spacing between holes. Select the line and the hole to move with the copy feature selected and use the line as the translation points. It's actually pretty quick. Then mirror the holes about a "line" to create the second column of holes. The hole pattern can be copied using the "Create Edges" option in the Contour Mode for the holes needed on the opposite side.
hope u people add this feature and that would help new users and software becomes user friendly
mohan kommineni
Country: AUSTRALIA
Kerry Fullington wrote:Mohan,
yes kerry exactly this is what i need can u upload the design so that i can compare it with the one what i have done
