SlaB Doors
Chris Harmon
Company Name: Azure Cabinets
SlaB Doors
Post by Chris Harmon »
The standard slab doors is not showing up right in the cut list. Is there a way to change this to get it right. Can you add edgebanding to slab doors?
Chris Harmon
http://www.azurecabinets.com
Re: SlaB Doors
The standard Slab Door has edgebanding, which the thickness is deducted from the size of the door. You can create edgebanding of 0" thickness for your doors to show on your list "as per".
Chris Harmon
Re: SlaB Doors
Where do you change the edgebanding?
Chris Harmon
Re: SlaB Doors
You can create edgebanding in Settings/Preferences> Define Stock Materials, then select Stock Type> Banding Stock.
Chris Harmon
Re: SlaB Doors
Thanks Rick,
I figured it out. I went to define doors and built slab doors with the edge banding thickness that I needed.
Chris Harmon
