reedwatts
Posts: 15 Joined: Thu, Feb 22 2007, 3:04AM
Post
by reedwatts » Fri, Sep 25 2009, 10:47AM
I am attempting to design a slant-front desk (secretary) and can not figure out how to angle the sides....
JohnLashuay
Posts: 645 Joined: Mon, Nov 20 2006, 3:39PM
Post
by JohnLashuay » Fri, Sep 25 2009, 11:43AM
You need to take each side panel to the part editor to cut the angle that you are looking for. You will also need to give the top shelf a front inset that will bring the front back to where the angle ends at the top of the panels.
-John
reedwatts
Post
by reedwatts » Fri, Sep 25 2009, 12:03PM
John --
Thank you for the reply. I hate to ask, but is it possible to walk me through it...how do I get into the parts editor...
reedwatts
Post
by reedwatts » Fri, Sep 25 2009, 12:37PM
John --
OK. This is how far I can go....How do I cut off the "triangle"?
JohnLashuay
Post
by JohnLashuay » Fri, Sep 25 2009, 1:26PM
With the picture that you are showing, take the "Filled Arc" (Half Circle) and apply it to the angle. Then highlight it and right-click, click on the "cut/Pocket Using Closed Contour". This will bring up a window that will give you an option to cut through or specify a depth. Check the "cut through" and then OK. This will remove that material.
Then highlight the little box that is in front of the shelf and do the same to remove that material.
-John
Posts: 5852 Joined: Thu, Jul 28 2005, 10:18AM
Post
by DanEpps » Fri, Sep 25 2009, 2:32PM
Try the steps in this video:
Angled Top Cabinet.zip
(3.98 MiB) Downloaded 485 times
Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Fri, Sep 25 2009, 2:49PM
If you make a DXF in SketchUp just your side then bring it into e-cab
reedwatts
Post
by reedwatts » Fri, Sep 25 2009, 10:53PM
THANK YOU DAN EPPS!!! I have been trying for a while to figure this out!!!
Post
by DanEpps » Sat, Sep 26 2009, 7:52AM
reedwatts wrote: THANK YOU DAN EPPS!!! I have been trying for a while to figure this out!!!
No problem! You can find this and a few other videos I've done on my website
eCabWorld .
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Sat, Sep 26 2009, 8:16AM
Reed,
There are also several good video tutorials available through eCabinets. On the opening screen of eCabinets select View Video Tutorials. There is one on the part editor. as well as other areas of the software.
