Problem with a moving countertop after PE cut
JohnLashuay
Post by JohnLashuay »
Can someone take a look at this job and let me know why this countertop is moving 3" after I take it to the PE and cut it.
-John
Oakly-Kitchen.esj
(7.15 MiB) Downloaded 324 times
http://www.rylexonline.com
Thermwood CS 43
Re: Problem with a moving countertop after PE cut
It must be in the program
I played with it for about 2-Hr's
I did make a DXF for you with the sink cut out
Base Cab_11-11-09.zip
(369.98 KiB) Downloaded 296 times
JohnLashuay
Thanks George for looking into this!! As much as I tried, I couldn't find a way around it so I deleted the back splash and just moved the top after I modified it.
Thanks again!
-John
Thermwood CS 43
