Fake Paneled Doors
Bryan J Tanner
Company Name: Decor Designz
Fake Paneled Doors
Post by Bryan J Tanner »
Hi we supply doors from a supplier that molds the MDF substrate and then laminates a vinyl to the front.
You can find them here http://www.arborlinedoors.co.nz
My questions is this, is there an easy way that I am overlooking to display a door or drawer in the style showen in the attached picture.
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
Re: Fake Paneled Doors
Bryan, You can take a Slab Door to the PE. There you can create tool paths to get the look your after. Here is a quick sample that I did in a few minutes.
tool paths.jpg (47.07 KiB) Viewed 36333 times
When I need a door like that
I make the in door maker start with a slab then I bring in a DXF that I make in a Cad program.
or you can make it in e-cabinets
Rick you beat me to it
Door 17 x 32.jpg (33.93 KiB) Viewed 36331 times
Bryan J Tanner
Thanks for that guys
I guess I was hopeing I'd missed something, and that there was a more automated way to do it.
Thanks again
HP Pavilion DV6
I put your picture on a Display Cube make sure you check on (Stretch) that way it will fit the panel
I made a sheet good as Piha .75 x 48 x 96
I made a borad stock as Piha
Piha Cabinets.jpg (41.34 KiB) Viewed 36318 times
Bryan J Tanner
Thats quite effective George!
HP Pavilion DV6
Paul Ford
Post by Paul Ford »
Hey Bryan,
You could possibly talk to Arborline if your are a high user of there doors and ask them for a copy of the dxf for you to import into eCabinets?
I forget the guys name there now who I used to deal with, I think it was Andrew somebody? That way you can import it into the part editor...
What I'm wondering is can a formula be entered into the Constraints Manager which would allow the equal expansion or contraction of the field?
Bryan J Tanner
Paul Ford wrote: You could possibly talk to Arborline if your are a high user of there doors and ask them for a copy of the dxf for you to import into eCabinets?
Hey thanks for that idea Paul. I'm over in Hamilton tommorrow, i might just call in and have a talk.
Rick Palechuk wrote:What I'm wondering is can a formula be entered into the Constraints Manager which would allow the equal expansion or contraction of the field?
Thats a good question Rick, i hope someone has an answer for us.
HP Pavilion DV6
Daniel Vonderheide
Post by Daniel Vonderheide »
Yep, it can be done. not with just one formula though. The attached door is saved as a cabinet and is only a sample. You can see the depth difference in the profile cuts because it is a sample.
parametric door.hsf
sample door
(378.02 KiB) Downloaded 2097 times
Thanks Daniel.
Jim Carter
Company Name: Jim Carter Corp.
Post by Jim Carter »
good morning
I downloaded the file "parametric door.hsf" to see how it works. But I do not know how to open it in e cabinets.
the file shows up in the drawbox section, how ever the drawer box editor will not open it.
jim
jim@jimcartercorp.com
973-224-0221
Ringwood, New Jersey
Daniel Vonderheide
it's a cabinet file. You will need to save it in one of your cabinet directories and open it in the cabinet editor.
Jim Carter
thanks Daniel
so now I know, I can create almost any patern on a slab door as a parametric, attach it to a cabinet as an assembly. And be able to scale the assembly.
very cool.
Jim
973-224-0221
Jim Carter
OOOPS;
I think I was wrong, I can not scale the assembly.
973-224-0221
