I have a problem where the bottom of the upper cabinet is finished. Inside the cabinet is white but the outside is laminate finish. I want to make a full deck with blind dado joints so that no screws will be needed and no lamination when the cabinet is being put together. The issue here is that if I select good one side material eCabinets will put the good side inside. I can't really flip the sheets on the CNC because it will interfere with other parts.
I understand that with my suggestion there would be a whole lot of flip operations but sometimes it's needed. What I need really is a way to choose which side is inside or outside
Upper Cabinet Deck
- Georgi Baltov
- Company Name: Top Notch Cabinets
Upper Cabinet Deck
Top Notch Cabinets
http://www.topnotchcabinets.com/
Roger Kirkpatrick
- Company Name: The WoodCrafting Company
Re: Upper Cabinet Deck
I always have finished bottoms on my upper cabinets also.
E-Cabinets always nests 2 sided material inside up.
The inside gets machined first, then you need to flip it for the tenons.
If you are using 2 sided melamine where both sides are the same it nests it
outside up. Then you need to flip it to machine the back dado.
So what is wrong with this?
The WoodCrafter
Gary Campbell
- Company Name: ShopBot Tools Inc
Georgi...
We do this fairly often when using materials with a different finish on each side. Some parts need to be cut with Outside finish up and some with outside finish down. (before flipOps) Sides can be cut OS fin down while tops and deck usually need to be cut with the OS fin up. It just takes a little work to define the proper material to make it work.
Gary Campbell
- Georgi Baltov
The problem is that in the same job for two different cabinets one side is in and on the other cabinet the same side is out.
Top Notch Cabinets
Roger Kirkpatrick
If you don't have the material setup correctly, 2 sided, you will get this for sure.
It might be a bug in V6 but I have not seen it.
The WoodCrafter
