Wood products
Wally Schneeberger
Wood products
Post by Wally Schneeberger »
I have a Osbourne Wood products CD and would like to add the proper files into Ecabs. Which ones do I have to copy and where should I put them. Should I just take the STL files and put them in Display Objects or what else do I have to do??
Re: Wood products
Wally,
You will have to open the .stl files in the display part editor and make any changes you want and then save them from there. They can then be used as display objects.
I have converted most of them and you can download them HERE
Unzip the files and then copy or cut the folder into your eCabinets import folder. You can then access them as display objects.
I have also done many of the Hardware Resources items and they can be found HERE
Wally Schneeberger
Re: Wood products
Thanks Kerry -- You saved me a lot of time AGAIN --
AaronAlbers
Re: Wood products
Post by AaronAlbers »
Thanks kerry
Aloha from hawaii :)
Bruce
