downloaded libraries
David Arde
Company Name: Can-Am CNC Creations
Post by David Arde »
I have downloaded some of the libraries from the design sharing but they do not show up in the program after I install them. The computer is not hooked up to the internet so I copied the files to it from my flash drive. Do I have to do something other than unzip them and run the exe file to get them to install. I have Windows 7 pro on the new computer.
David Arde
Re: downloaded libraries
I guess no one else has had this problem
Kenneth Rychlik
Post by Kenneth Rychlik »
Look and see whre your normal cabinets are.
Make sure the downloaded libraries are saved into the same area so you can find them.
I don't remember the string of C:/....ect off hand but someone may chime in with it.
Kenneth
David,
Your Version 6 cabinets will be in your Shared Documents Folder.
In XP the path is C:\Documents and Settings\All Users\Shared Documents\Thermwood\eCabinet Systems\Cabinets
The path is a little different in Windows 7 but look for your shared documents.
