Measure tool error?
Measure tool error?
When I use "Maintenance Tool Unload" to return a bit to the typewriter head to take out a dull bit and use "Maintenance Tool Load to return a new bit to the spindle I'm getting an error when I go to measure that bit. It says " Invalid AFL statement, maybe files may be open" I read it twice to make sure I was reading it right! Then I have to exit Supercontrol and restart it then I can measure the bit as usual without the error.
Re: Measure tool error?
Hello Terry, What version of THM software is on your control currently? Try pressing "Ctrl" and "V", it should pop up on the screen. Thanks
Thermwood Technician
Carl,
ver 7.4.5.10 installed about 2 months ago.
Hello Terry, what is a good number that I can reach you? I will call you. Thanks
Hi Carl,
(724) 925-9100
(724) 925-9100
