Cross grain
Georgi Baltov
Cross grain
Post by Georgi Baltov »
How do you nest a crass grain sheet? Meaning if the sheet is 48"x 96" but the grain runs along the 48".
I am sure there is a ways around I am just too lazy or dumb (pick one) to figure it out.
Re: Cross grain
Create the material so the dimensions are w96xl48.
Georgi Baltov
Re: Cross grain
I did and the nest diagram doesn't look very promising. I also tried to add sheet but even I selected "Y" as grain direction it would not add the sheet.
Any other advise?
Cross Grain.zip
(84.64 KiB) Downloaded 316 times
Re: Cross grain
I see what you mean..... Maybe if you create the cabinet with the grain turned 90 degrees?
Georgi Baltov
Re: Cross grain
That's probably the only way to do it. I never needed to do anything like that before but we have some cross grain material leftover from paneling job and now I want to use it.
I was sure though that there would be a way to cheat the machine at the CN. Smart Thermwoods, what can I say! :wink:
Re: Cross grain
There was a previous discussion about rotating parts at the nest for cutting nonessential parts (toe kicks,etc). Maybe that needs to be brought up again.
