Georgi Baltov
Posts: 341 Joined: Sat, Mar 10 2007, 7:31PM
Post
by Georgi Baltov » Fri, Apr 30 2010, 11:27AM
How do you nest a crass grain sheet? Meaning if the sheet is 48"x 96" but the grain runs along the 48".
I am sure there is a ways around I am just too lazy or dumb (pick one) to figure it out.
Posts: 1896 Joined: Wed, May 18 2005, 7:54PM
Post
by Rick Palechuk » Fri, Apr 30 2010, 12:53PM
Create the material so the dimensions are w96xl48.
Georgi Baltov
Post
by Georgi Baltov » Fri, Apr 30 2010, 2:12PM
I did and the nest diagram doesn't look very promising. I also tried to add sheet but even I selected "Y" as grain direction it would not add the sheet.
Any other advise?
Cross Grain.zip
(84.64 KiB) Downloaded 315 times
Post
by Rick Palechuk » Fri, Apr 30 2010, 2:30PM
I see what you mean..... Maybe if you create the cabinet with the grain turned 90 degrees?
Georgi Baltov
Post
by Georgi Baltov » Fri, Apr 30 2010, 3:37PM
That's probably the only way to do it. I never needed to do anything like that before but we have some cross grain material leftover from paneling job and now I want to use it.
I was sure though that there would be a way to cheat the machine at the CN. Smart Thermwoods, what can I say!
Post
by Rick Palechuk » Fri, Apr 30 2010, 4:00PM
There was a previous discussion about rotating parts at the nest for cutting nonessential parts (toe kicks,etc). Maybe that needs to be brought up again.
