Ray Jorgensen
Posts: 199 Joined: Sat, Jul 29 2006, 9:11AM
Post
by Ray Jorgensen » Thu, May 13 2010, 12:23PM
Does anyone have a clipped corner cabinet that they would like to share? I'm having a little problem getting my head around how to do these.
JohnLashuay
Posts: 645 Joined: Mon, Nov 20 2006, 3:39PM
Post
by JohnLashuay » Thu, May 13 2010, 1:44PM
Ray, is this what you are looking for?
base_corner_angle_24x34.5 - 36x36.jpg (9.7 KiB) Viewed 23524 times
base_corner_angle_24x34.5 - 36x36.hsf
(566.02 KiB) Downloaded 1561 times
Ray Jorgensen
Post
by Ray Jorgensen » Thu, May 13 2010, 2:26PM
Thanks John I should have used a better description. I need to angle "clip" the front corner of a base cab on the end of a run. It will be clipped on the right hand side. Hope that is clearer.
Kenneth Rychlik
Posts: 161 Joined: Thu, May 04 2006, 11:09AM
Post
by Kenneth Rychlik » Thu, May 13 2010, 6:23PM
Is this getting closer?
Kenneth
Corner Base Diagonal.jpg (10.92 KiB) Viewed 23503 times
Corner Base Diagonal.hsf
(474.02 KiB) Downloaded 1481 times
Ray Jorgensen
Post
by Ray Jorgensen » Fri, May 14 2010, 6:26AM
Nope Kenneth, I need a 20" wide 24" deep base with the right side measuring 20".. Now clip the corner at a 45. That corner will be a "finished" piece with the door to the left of that. If I keep at this maybe I'll make myself clear!!! Thanks
Dennis Englert
Post
by Dennis Englert » Fri, May 14 2010, 7:28AM
Ray,
On the 20" side, use a 4" inset on the front to adjust. Chamfer the corner of that part 45 degrees with the Part Editor. You might also restrict it with the Constraint Manager. Install a door, but increase the reveal on the chamferred corner to adjust for the placment of the door. A display panel or display board would have to be manually placed on the chamfered corner and associated with the cabinet to save it.
If this is a face frame cabinet, then you'll need to play with negative scribes on the chamfered corner. There's a little more math, but all doable.
Dennis
Dennis Englert
Post
by Dennis Englert » Fri, May 14 2010, 7:29AM
Correction: Chamfer the corner of the top, deck and any shelves, not the end panel.
Sorry about that.
Dennis
Gary Puckett
Posts: 1324 Joined: Mon, May 19 2008, 1:39PM
Company Name: The Woodworkery
Post
by Gary Puckett » Fri, May 14 2010, 7:32AM
Ray,
Can you draw a overhead view of the cabinet to show us.
JohnLashuay
Post
by JohnLashuay » Fri, May 14 2010, 8:45AM
How about this one? It is a corner cabinet that would need more modification.
-John
Base_20_Front-Rt-Clip.hsf
(160.02 KiB) Downloaded 1458 times
Ray Jorgensen
Post
by Ray Jorgensen » Fri, May 14 2010, 9:08AM
John,
That's what I was looking for!!!! From there I can see how you did it a proceed. Thanks
Dan Calvert
Posts: 19 Joined: Tue, May 09 2006, 1:43AM
Company Name: Calvert Custom Cabinetry
Post
by Dan Calvert » Fri, May 14 2010, 10:14AM
Ray,
Here is another style of clip corner cabinet.
Clipped Corner Top View.jpg (12.29 KiB) Viewed 23380 times
Clip Corner Cabinet.jpg (23.24 KiB) Viewed 23380 times
Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Fri, May 14 2010, 12:50PM
This is all you get on Friday Ray
It is 3 Cabinets
Test 5-14-10.esj
(790.02 KiB) Downloaded 1537 times
Test 5-14-10_2.jpg (86.25 KiB) Viewed 23369 times
Test 5-14-10.jpg (42.33 KiB) Viewed 23369 times
