clipped corner cabinet
Ray Jorgensen
Post by Ray Jorgensen »
Does anyone have a clipped corner cabinet that they would like to share? I'm having a little problem getting my head around how to do these.
JohnLashuay
Re: clipped corner cabinet
Post by JohnLashuay »
Ray, is this what you are looking for?
base_corner_angle_24x34.5 - 36x36.jpg (9.7 KiB) Viewed 23512 times
base_corner_angle_24x34.5 - 36x36.hsf
(566.02 KiB) Downloaded 1561 times
http://www.rylexonline.com
Thermwood CS 43
Ray Jorgensen
Thanks John I should have used a better description. I need to angle "clip" the front corner of a base cab on the end of a run. It will be clipped on the right hand side. Hope that is clearer.
Kenneth Rychlik
Post by Kenneth Rychlik »
Is this getting closer?
Kenneth
Corner Base Diagonal.jpg (10.92 KiB) Viewed 23491 times
Corner Base Diagonal.hsf
(474.02 KiB) Downloaded 1481 times
Ray Jorgensen
Nope Kenneth, I need a 20" wide 24" deep base with the right side measuring 20".. Now clip the corner at a 45. That corner will be a "finished" piece with the door to the left of that. If I keep at this maybe I'll make myself clear!!! Thanks
Dennis Englert
Post by Dennis Englert »
Ray,
On the 20" side, use a 4" inset on the front to adjust. Chamfer the corner of that part 45 degrees with the Part Editor. You might also restrict it with the Constraint Manager. Install a door, but increase the reveal on the chamferred corner to adjust for the placment of the door. A display panel or display board would have to be manually placed on the chamfered corner and associated with the cabinet to save it.
If this is a face frame cabinet, then you'll need to play with negative scribes on the chamfered corner. There's a little more math, but all doable.
Dennis
Dennis Englert
Correction: Chamfer the corner of the top, deck and any shelves, not the end panel.
Sorry about that.
Dennis
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
Ray,
Can you draw a overhead view of the cabinet to show us.
JohnLashuay
How about this one? It is a corner cabinet that would need more modification.
-John
Base_20_Front-Rt-Clip.hsf
(160.02 KiB) Downloaded 1458 times
Thermwood CS 43
Ray Jorgensen
John,
That's what I was looking for!!!! From there I can see how you did it a proceed. Thanks
Dan Calvert
Company Name: Calvert Custom Cabinetry
Post by Dan Calvert »
Ray,
Here is another style of clip corner cabinet.
Clipped Corner Top View.jpg (12.29 KiB) Viewed 23368 times
Clip Corner Cabinet.jpg (23.24 KiB) Viewed 23368 times
This is all you get on Friday Ray :lol:
It is 3 Cabinets
Test 5-14-10.esj
(790.02 KiB) Downloaded 1537 times
Test 5-14-10_2.jpg (86.25 KiB) Viewed 23357 times
Test 5-14-10.jpg (42.33 KiB) Viewed 23357 times
