Equal door sizes
Simon Burrows
Equal door sizes
Post by Simon Burrows »
Hi,
Does anyone know how I can quickly achieve equal door sizes on a long cabinet (built-in wardrobe) this one always gets me, I end up spending loads of time trying to calculate cabinet widths to achieve equal door widths over a given run.
Many thanks,
Simon
The learning curve can be comfortable if all resources are applied
Re: Equal door sizes
Here is an Excel spreadsheet that will do the calculations for you. Enter the information in B1 through B5 and the output will be shown in B10 through B20 with the corresponding equation listed to the right of each result.
Door Equalizer.zip
(2.61 KiB) Downloaded 715 times
You could use the Equalize feature in Custom Layout. Create an alcove, place desired amount of cabinets. hilte the cabs click Equalize. You now have equally spaced doors.
119 wall.png (102.33 KiB) Viewed 5573 times
119 wall 2.png (60.84 KiB) Viewed 5573 times
Simon Burrows
Thats brilliant,
thank you both so much, I'm gonna have a play around with them both,
Cheers,
Simon
