I haven't seen anyone mention this yet with 5.59, but we just cut our first job with it today, and several of the offfalls overlapped the parts, both on the nesting diagram AND on the actual material, therefore the parts were cut when the machine cut the offfall. Looking at the nest diagram, it's like the offfall portion of the sheet has been shifted toward machine home by an inch or two.
We're using metric if that makes any difference. Let me know if I need to post the export or if you need more information.
Offfalls cutting into parts
- Jeremy Schiffer
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
Ryan Hochgesang
Re: Offfalls cutting into parts
Please email EXPORT file along with design files (.esj, .hsf, or .esa) to: program@thermwood.com and we will have a look.
Thanks!
Thanks!
- Jeremy Schiffer
ok ryan i will get 2 that 2mrw
Dan!)
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
Jason Stephenson
- Company Name: Marks Joinery
We are having the same problem with our off falls aswell what we have done have just got no offfalls when we nest! we have been informed that they are working on fixing it!
Jason
Jason
Ryan Hochgesang
I'm not sure who would have said this is known, but I have checked with our engineering group and this item is not listed as an issue. Please submit supporting files (EXPORT, .esj, .hsf, .esa, etc...) to: program@thermwood.com for further review.
Thanks!
Thanks!
- Jeremy Schiffer
Hi Ryan,
I've attached the job file and the CN export. Let me know if you need anything else.
Thanks!
Thanks!
- ControlNest5-59.zip
- (147.12 KiB) Downloaded 467 times
- 240 n ga tech cnc.zip
- (2.04 MiB) Downloaded 514 times
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
