HI I have a corner cupboard that is 1475 x 1475 with a back corner inset of 900 mm was just wondering if there was a way to check that the deck width is 560mm deep! and also was wondering how to nest it in to 3600mm x 1200mm sheet it nest into a 2400 x 1800 and was just wondering whether you could do this because there seems to be alot of offall
Thanks Jason
Hi Jason. You should be able to check the deck depth in the cabinet editor using the measuring tool. You will not be able to nest a component wider than the sheet size in eCabs but if you are using a Thermwood you can rotate the components in Control Nesting and it will nest there. So probably best to use a sheet stock 2750 x 1830 or 1800 x 2400 as you said
